sam37
Grip
- Jul 29, 2008
- Sam
Hey there. I have 1 set of speakers left to buy and I would like some assistance in deciding what I need.
I'm wondering what advantage dipole speakers provide, and do I need to go with those or just regular speakers (direct radiating I guess they are called).
As far as room acoustics, well, I can just describe the setting of my living room. I live in an apartment, and my living room is open to the kitchen. Where I sit is with the main part of the living room with the kitchen area behind me, so the total room space is longer than it is wide, i.e., the couch is about 10 to 12 feet from the tv, and then there is about 12 to 15 feet of space behind me. The room is about 14 feet wide.
So with this setup, i'm not sure if i need to go with regular speakers or dipole for my surrounds.
If it is dipole, i know which speakers I am going to buy, but if it is regular speakers, then i'm not sure. If it is regular, do the surrounds have to be a special type, or can the surrounds be just another set of front speakers? In other words, could you use a set of front bookshelf speakers as your surrounds?
