Mike Clemens
- Feb 6, 2005
First, let me explain my modest HT setup. After 12 years, I retired my 65" Panasonic Plasma and replaced with 85" Samsung QN90A. I need to upgrade my AVR to one which handles 4K and Dolby Atmos. My 7 year old Yamaha does not.
I have a 5.1 surround setup with L C R, BL, BR and sub. I cannot install ceiling speakers but I will put upward firing speakers on top of the front towers. I use ROKU for TV and will also need to upgrade my Blue-Ray player to 4K. I do NOT play games, only watch TV and movies.
I was never really thrilled with Yamaha and I'm looking at the Denon X4700. My new TV is 4K and I plan to keep it as many years as the old one, provided that it holds up. The 4700 is 8K, which I won't use and probably has more channels than my speaker setup will use. Do you think this is overkill? If so, can you recommend a solid AVR that I should look at?
Thanks for all your help. I appreciate it.
