Hi, this is my first time posting. I've seen many posts about receiver comparisons, but I think they really depend on the speakers you have, so everyone will have different answers as to which to get. As for me, I have a set of 5.1 NHT's (ST4 fronts x2, SB3 rear x2, SC2 center, and SW-12 sub) and am deciding among those 3 receivers.
I first looked at the Onkyo because its Net-Tunes feature really tempted me, as most of my music collection is in mp3 format. But after looking various user comments about it, I found out that it seemed really lacking compared to other wireless media centers. I'm currently testing the Onkyo with a wireless ethernet bridge (which in theory can hook up the Onkyo to my wireless network), but so far only the net-raio has worked and not the music server that shares mp3's on my computer. If the Net-Tune feature isn't really worth it, I might as well return the Onkyo and check out other viable receivers around the same price range. Since I've heard many good stories about the Denon and Marantz I thought I might as well give them both a shot.
According to PriceGrabber.com The Onkyo go for around 600, the Denon low 700's and the Marantz mid 700's. I'm not sure if anyone else has the NHT's, but I have no idea how do they compare to other speakers (whether it sounds warmer or colder) since I've never tested any other speakers and mainly bought them for their looks over their reputation, and for the really good discontinued price. I do know that the Denon is supposed to sound warmer than the Onkyo. Since all 3 receivers has very similar features, the compatibility with my NHT's should be the deciding factor. I plan to do about 70% movies and 30% music with my receiver in case if that should decide which receiver is more fitting.
I would greatly appreciate any help and thank you all for your patience
