Richard Cook
- Aug 12, 1999
Hi folks
You may all remember that I had some problems with my Denon 2802 receiver, whereby the output kept failing?
Well, if you remember, Sevenoaks Hi-Fi tested it and found it to be OK in the shop. After 3 weeks, the output stage has failed again so I'm taking it back again, this time for Denon to check it over, as it is obviously an intermittent fault, possibly a loose connection.
Wish me luck, I'll let you all know the outcome.
Only problem is I'll be without hi-fi for a couple of weeks. Cest la vie
