Devilish21ca
- Jan 24, 2008
- David Sheedy
Good day; I'm about to pull together a home theatre project that includes a PAN TH58PZ700U plasma, an Onkyo SR805 reciever, Definitive Mythos speakers, an HD DVD player, and a HD PVR (cable). It will all sit in an in-wall cabinet with one of those pull-out-rotate gear racks. I have two questions:
1 - Do I need to 'clean' the power on the way in (or otherwise regulate it) or is a really go surge protector sufficient? I've no problem getting it if it is needed, but I don't want to buy more than I need either. Also, since the room is being wired, how should the AC be made available to the gear area?
2 - We are probably going to have a cabinet door in front of the gear; this would seem to indicate I need an RF remote, though I could go with an IR kit that runs through the all to the cabinet. Any recommendations on which is better, and a manufacturer?
Thanks in advance,
David Sheedy
Thanks in advance,
David Sheedy
