Chane speakers mini-review (1 Viewer)
blah
Dan
FYI for folks looking for an excellent setup without breaking the bank (no affiliation)
http://www.chanemusiccinema.com
Background:
Audiofool of some 20 years and a classical musician for longer than that. In audio I've designed and built just about everything, conventional speakers, I've had planers, horns, 'stats and many many tube and SS amps/preamps. My house turned out to have the perfect spot for a 120" screen and theater so I took the plunge into this world.
Now for Cinema I believe you have different needs than for two channel music. Movie sound tracks aren't "real" - they're highly manipulated mixes comprising many different sources. So I don't think the rules and expectations from two channel classical music apply here. So with that in mind I've been looking for a system which is immersive, non fatiguing, detailed (but not too detailed) and with low distortion at the high SPL's that movies like to throw at us on occasion.
Interesting design with split gap drivers to keep distortion down at higher SPL and flat tweeters (not ribbon). The enclosures are solid top drawer speaker grade MDF with excellent (but not insane) metal film caps and wound inductors. Looked like a promising design so I auditioned (in home) and eventually outfitted a 7.1 system with Chane speakers.
My Setup.
  • 7.1 as stated (still using a crappy Monoprice active sub for below 45 Hz approx)
  • 3 L-C-R using three A2rx-c in front (LR vertical C horizontal with a rotated tweeter).
  • 4 A1rx-c on satellite duty (vertical)
  • Total cost - approximately $1300
Results:
Excellent, exactly what I'm looking for. I believe the tweets are giving me a somewhat 'planer like' experience without having to deal with the trouble of full Maggies. The sound field is fully immersive and wide. There's no sweet spot here which is what you don't want with Cinema. You obviously want all the viewers to get an equal sound field if possible. For home cinema this design provides that.
Detail is excellent, but as I said I don't want to hear too deeply into their mix. Sound effects, audio tracks (usually not real instruments), and even voice is something that needs to be believable but not real. These provide the right amount for me. At high SPL's distortion is truly low. On two channel I'm a distortion/detail freak, so am highly sensitive to this (comes from my music background). These get quite loud at moments and I can handle it - enjoy it actually which is unusual for me.
Integration. This is really important for a 5.1/7.1 system. In this case the same mid and tweet is used across the line, and in my case I used the exact same speaker for the front three, just with the center rotated. The front field is perfectly integrated, and the sides fit right in beautifully.
In the home. The speakers are small, and best is that the A2rx-c fit perfectly under my screen which is 3' above the floor. With my setup (I'll try and post pictures later) regular floor standing LR pairs don't work. The speakers have a black very high quality PVC finish (I don't want some more expensive wood grain or whatever) that fits well in the space.
I should add, having high quality and integrated satellites does make a difference. A huge one? Well, I'd say that cheap satellites will get you 80% of the way there, but the last 20% subjectively seems more than it is (you cross the 'uncanny valley'). This is in tests with this system before I got the A1rx satellites. So if you can afford the extra $300(5.1) or $600(7.1) then I suggest doing it. If not then a L-C-L A2rx for some $700 will do wonders.
Conclusion: I couldn't be happier. I still need to find permanent stands but the sound field is just what I want for Cinema. Pro-tiup, make sure you let the speakers break in, and if you can manage it do the 3xA2rx-c in front as I did.
blah
Dan
Phil A said:
Thanks for the review. What electronics are you using with them?
Nothing special at the moment. Other than the screen (Carada) and projector (Epson 6030) I chimped out on the other parts to give me time to figure them out. Since I've upgraded to a Oppo BD player (which I like but I'm not impressed with the plugins (e.g. Netflix)) and now the speakers. Only remaining is to upgrade the amplifier at some point. I won't go with anything particularly special as I think that would be counter productive. I have used some of my high end gear with the Cinema (e.g. Stax electrostatic headphones) and found it less than optimal.
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
I wonder how these stack up to HTD level 3. I Googled that, shockingly enough, there were tons of results.
Inexpensive ribbon/flat tweeters for the masses...which is a good thing.
I do see that Chane is following the Ford School of Color Choice...
blah
Dan
Again to be clear it's not a ribbon tweeter. AFAIK it's simply a conventional driver with a planar dome.
John Garcia
NorCal
I haven't heard the current ones but listened to the previous bookshelf, the A1B, in a critical listening session with a friend who owns them. They sounded good, but the tweeter lacked some fine detail and was ever so slightly sibilant when pushed hard. The mids were excellent and bass pretty good.
Phil A
Central FL
Phil
My favorite tweeter is Raal (http://www.raalribbon.com/products.htm). I'd love to get a pair of speakers with them but have too many systems and no place for them. Almost sold a pair (and center) of speakers I had in a spare system before a move last year (with the intent of buying something with Raal tweeters) but I didn't have the time to really put a good effort into the sale.
blah
Dan
Yes I'd agree that the tweeter lacked some fine detail. That's a good think IMO, as I say I don't really want to get too high resolution on movie tracks. Old movies often just sound, well kind of bad (I need to look it up again but I think there wasn't much bandwidth allocated for the audio track) and modern movies are so highly manipulated. For my headphone setup I have a tube OTL headphone amp with a variety of cans (including extraordinarily resolving Stax) that I can use. I find a balance when it comes to detail, more detail isn't better after a certain point. Edit - when it comes to cinema that is! Two channel music can never offer enough detail IMO.
At any rate at the end of the day while watching a movie I just want something relaxing and involving, and they work great without being super expensive.
John Garcia
NorCal
Agreed. I tend toward soft domes because they give a pleasant top end that is often soft but pleasing, like my current music speakers, Dennis Murphy CAOW1s. Really comes down to what you like and I definitely don't like brighter speakers for movies.
blah
Dan
On the Chane I really do like the finish. Doesn't bring attention to itself, is highly durable and looks good on close inspection.
Not trying to sound like I'm pushing the speakers but I am pleased with them.
mycuu
