latrapeze
- Oct 15, 2006
- Phil St.Onge
What are the differences (in layman's terms) between these two surround speakers and can I get away with using one or the other in my HT system?
Here are the specs.
SS-1 Specifications
FREQUENCY RESPONSE
65Hz-20kHz±3dB
POWER HANDLING
100 watts maximum continuous (400 watts peak)
SENSITIVITY
94dB @ 1watt/1meter (equivalent sound energy)
NOMINAL IMPEDANCE
8 ohms
TWEETER
Two K-101-S 1" (2.54cm) Aluminum dome compression drivers
HIGH FREQUENCY HORN
5" square 90°x60° Tractrix® Horn
WOOFER
K-1076-S 5.25" (13.34cm) IMG cone / cast polymer frame
ENCLOSURE MATERIAL
Medium density fiberboard construction (MDF)
RS-10 Specifications
FREQUENCY RESPONSE
82Hz-20kHz +/- 3dB
POWER HANDLING
50 w (200 w peak)
SENSITIVITY
91 dB @ 2.83 volts/1 meter
NOMINAL IMPEDANCE
8 ohms
CROSSOVER FREQUENCY
2000 Hz
TWEETER
Two 1" (2.5 cm) titanium dome compression drivers
HIGH FREQUENCY HORN
2 x 4" (10.2 cm) square 90° x 60° Tractrix Horns
WOOFER
One 4" (10.2 cm) Cerametallic cone woofer
Here are the specs.
SS-1 Specifications
FREQUENCY RESPONSE
65Hz-20kHz±3dB
POWER HANDLING
SENSITIVITY
NOMINAL IMPEDANCE
8 ohms
TWEETER
HIGH FREQUENCY HORN
WOOFER
ENCLOSURE MATERIAL
FREQUENCY RESPONSE
82Hz-20kHz +/- 3dB
POWER HANDLING
50 w (200 w peak)
SENSITIVITY
NOMINAL IMPEDANCE
8 ohms
CROSSOVER FREQUENCY
2000 Hz
TWEETER
HIGH FREQUENCY HORN
WOOFER
