ENIGMACODE
Hi Gang
Everyone here are helpful, courteous and professional - that's what makes a discussion forum a great place in which to post questions freely (thank you)!
I've owned two Yamaha recievers over the years (enjoyed them), from an HTR-5835 to an RX-V467. But I was a bit behind the curve. As recievers evolve and technology continues to standardize, naturally we're seeing fewer ports as certain technology becomes less demanding. I still have a few older pieces of equipment specifically an older 'Compact CD Changer' limited to analog and optical outputs, (naturally I prefer a digital transfer). So now I'm shopping for a later model 5.1 reciever with 'ARC' but I'd like to still connect my older 'Compact CD Changer' ...
There's a 'budget model' 'Yamaha RX-V385BL' on Best Buy for $299, but it only has ONE optical port which is typically labeled for a TV. Can I assume the audio will be reliably connected thru 'ARC' matched with a recent model TV also with ARC, thus allowing a free optical port for the CD Changer? *Hopefully I can re-assign (using the remote), to indicate audio for the CD Changer? But am I 'over looking' any unforseen shortcomings/problems/conflicts? Rear connections: RX-V385
Thanks Again!
Production Project - North Africa WWII
Thanks Again!
