Jon_H
- Feb 22, 2000
Hello everyone. I think my next project over the beginning of the winter is building myself a new sub. About 2 years ago I built a sonosub with a Tempest sub, it was a dual 4" ported downfiring sub tuned to about 19hz powered by a ~150watt Soundstream M1 monoblock THX amp.
I was very pleased with the performance of this setup. Unfortunately I had to sell the sub due to the shear size of it :frowning:
I still have the amp and really want to make a new sub, I need it to be small so I was thinking of a sealed box sub. (I think a ported box sub would need to be too big, no?)
I would still like to use the tempest because I have had a great experience with adire and there products. (unless anyone else could suggest any other driver)
So pretty much m questions to get started are:
[*]Do I need to build my sub as a sealed enclosure to keep down the sheer size of the sub?[*]If I do need to build a enclosed cabinet, what size should I make it to partner with the tempest well[*]should it be downfiring (im pretty sure it should)[*]would my current amp be enough to power an sealed tempest?[*]When I plot a sealed tempest on winISD i see that it really doesnt go that low in frequency compared to a ported sonosub, can anyone make a comparison between the two, pros and cons, will I be missing much that the sealed sub wont go that low
I think thats all the questions for now, Thanks for looking at my thread!
Jon
Jon
