Brian Dobbs
I'm not interested in enhanced stereo. Give me more MULTICHANNEL!
I may be wrong, but I suspect that one of the main reasons for some of the differences we hear is that the sort of processing (loudness wars, etc) used on CDs for the average listener are not applied (or not applied as often or as much) to SACDs/DVD-As, because they know the target audience don't want it.Doug Otte said:I guess that depends upon the listener's ears. I listen in stereo, and I can definitely hear a difference between a CD and an SACD. Admittedly, the difference is smaller w/ my Sony 5400, because it apparently smooths CDs by converting them to DSD, but I can hear it. On a few occasions, I played the CD layer of a hybrid SACD by mistake, and I could hear the lower quality before I looked at the display. Of course, we're assuming that the CD and SACD layers are from the same master.
It's not the ears, it's the mastering. I tried to do a direct level matched A/B comparison between SACD and redbook, and every hybrid SACD I found had different mastering on the redbook layer than on the SACD layer... obvious differences in fade outs and balances. I wash't able to make a fair comparison until I tried a Pentatone DSD mastered SACD hybrid. The disk sounded phenomenal, but other than a small difference in volume, the two layers sounded identical.Doug Otte said:I guess that depends upon the listener's ears. I listen in stereo, and I can definitely hear a difference between a CD and an SACD.
I have the Ella And Louis BRD. It's good but it sounds a shade too smooth for my taste. I prefer the clarity available from the original vinyl albums.AnthonyClarke said:I have six Blu ray audio discs to date ... the Getz Gilberto jazz album, Ella and Louis, soprano Anna Netrebko recital album, Carlos Kleiber conducting Beehoven 5th and 7th, and the Stones Exiles on Main Street and The Who's Tommy.
I have a few of these already on SACD (Getz, Kleiber and Tommy) and have to report that the same clear audio improvement is evident compared to CD (lack of compression, better definition especially in transfers from analog material) and there seems to be a slightly sweeter warm sound and a deeper bottom-end but I'm not sure if that's due to the encoding, or a new transfer or what . . . . .
The advantage of Blu ray AudIo is not just its superior sound compared to CD but to the fact a special player is not needed .. these discs will play on all Blu ray players.
Within a few years of CD coming out, many people with decent hearing were complaining about the sub-standard sound quality. Chesky responded by remastering two analogue recordings at 24/96 and releasing them on DVD: Red Rodney and Rachmaninoff Symphonic Dances/Donald Johanos/Dallas Symphony Orchestra. Both quickly became collectors' items among audiophiles, and quite rightly so. The sound quality is superb.Bobby Henderson said:I disagree with the notion 16-bit 44.1kHz audio (Red Book CD standard) surpasses anything the human ear can hear. It may go to the upper 20kHz and lower 20Hz limits of most ears. But that bit depth and sample rate doesn't capture all of the detail in the audible frequency range. 24-bit 48kHz does a noticeably better job. Most movies played in theaters use LPCM tracks mastered at that resolution. Music material can yield the biggest differences if it is mastered properly. 24-bit 96kHz is worthwhile for that.
