OliverK
- Feb 1, 2000
According to Black Magic 2k and 4k acquisition soon will be no problem provided that suitable 16 or 35mm elements can be found:http://www.blackmagicdesign.com/products/cintelPretty powerful stuff there, but not really plug and play considering that movies also have sound. I also hope that the grain reduction can be defeated or adjusted:The Cintel film scanner will include everything for a computer solution to film scanning and grading. You get the Cintel scanner with powerful built in Image Mill stabilization and grain reduction, a single 35mm film gate (16mm purchased separately), two film spools, a set of four cleaning rollers, DaVinci Resolve 11 software and desk mount feet included. Unlike many film products, with Blackmagic Design you can be assured there are no fees for installation, no software update fees, no ongoing license fees and no fees if you ever should want to sell your Cintel scanner or, if you want to buy a second hand one in the future there are absolutely no transfer fees!I wonder if people will get it to scan and release movies that are in the public domain...
