World Wide Stereo
BFD - Humm....noise.......driving me nuts (1 Viewer)
James Mudler
Hello and thanks for looking
I have recently added a BFD and have a horrible humm thru the subs. I have read Sonnie's great BFD FAQ and tried several searches here with no luck.
I have tried the cheater plug
Unhooking the TV cable
Gains
About my set up. All my equipemnt is rack mounted with rack ears. Connections are: Lexicon DC2 preamp > BFD > Kenwood KMZ1 amp > (2) PE 15 DVC's. The BFD power is connected to a panamax 1000+ with is switched via the preamp. I will be moving it over to a "always on" terminal for the turn on thump. I tried turning on the BFD before the amp, after, and same time - all thump. I and using the XLR input - I cut an rca cable and pin 2 hot signal - pin 1 and 3 to ground.
Please any advice would be welcomed. My next option is to remove it and go to a differ piece. TIA
Allen Ross
umm i have the Panamax 1000+ and a BFD and i am fine, I have my BFD on all the time same with the Panamax.
Have you tried running your sub with just RCA, my guess is the conversion to XLR from RCA, not 100% but just a guess.
samrinriya
