So I touched in this before. Looking for an accurate answer. So I just bought a Samsung outdoor tv. I also have four outdoor speakers being powered by a Sonos amp. My cable box and my Sonos amp is about 70ft away. So we are using Atlona hdmi extenders that support audio also. (Through optical on each side). I believe model 100cea. On the Sonos amp side I have a hdmi dongle from Sonos to covert the optical to hdmi. The run is over cat 6e.
Here is the issue. Having issues using my Samsung remote to control the cable box and the Sonos amp. Atlona has the ir connections on the tv side and the cable box and Sonos amp side. According to Samsung it should work. Also according to Best Buy. Best Buy who did the install thinks it’s a remote issue. So waiting on a new remote. And then to figure it out. For some reason I think it’s a Best Buy installer error. Can anyone give me some feed back. This whole setup works fine inside in my den but with using a indoor tv and hdmi connections. The Samsung remote controls everything.
