Tod
- Mar 20, 1999
I searched for "DVI" related threads and did not find the answer I seek, so here is my question:
I bought a 36" Sony XBR450 about 2 years ago. I have since learned about how DVI-HDCP (or DVI-HDMI) inputs will be needed on HDTV televisions in order to watch some copy protected HD material (e.g. movies). http://dvi.baumannpaper.com/
So am I simply S.O.L. with my XBR450? Does anyone know if there will be a way to upgrade my TV to add a DVI input? Or will there be some sort of set top box I can use to covert a DVI output to interface with a component input?
I'm sure this has all been discussed here before, but as I said I did a search and didn't find anything on it. Can you all please help enlighten me?
Thanks!
Todd.
Thanks!
Todd.
