Locut0s
- Dec 30, 2006
- Thomas
Ok so here's my current setup to start things off:
TV 50" Sony Grand Wega model KF-50WE620 (720p/1080i) (DVI in)
HDTV cable box from our local cable company here in Canada (a Motorola DCT6200)
XBox 360
PS3 60GB
old VCR
cheapish DVD player with HDMI out (NOT currently hooked up)
Pioneer VSX-D608 receiver
Cheap set of Sony home theatre speakers (one of those cheap 5.1 home theatre speakers in a box set ups you can find at most home audio stores).
The Pioneer receiver is an A/V receiver that can only handle low def RCA jack and S-Video inputs, though it does have 3 optical inputs and an optical output. All the audio is routed through the receiver using the 3 optical inputs for the high def sources and analogue inputs for the rest. The VCR is the only source to send its video to the receiver.
The video sources are hooked up to the TV as follows:
Cable box - Component
Xbox 360 - Component
PS3 - HDMI to DVI cable
(the now unhooked DVD player has both HDMI out and component but there are no more high def inputs on the TV)
The Sony KF-50WE620 is as I mentioned above capable of a max of 720p or 1080i, not 1080p. Anyone know if this will be a problem in the future with 1080p movies when and if they enforce the encryption bit turned on on all discs(forget the name of it)? Currently blu-ray movies look very good at 1080i on this screen! We are VERY UNLIKELY to upgrade this TV anytime soon (frankly I don't see the need so long as I can play any sources at 720p or 1080i I'm a happy man and don't notice much of a difference. The receiver and speakers are another story and need an update. So here's what I want in a receiver. The receiver must be able to do the following:
* Switch between the 2 DVI/HDMI sources (having a 3rd source for a DVD player would be a definite plus! but not mandatory)
* Have one HDMI/DVI otput to the TV
* Be able to at least pass all sources of video to the TV via HDMI/DVI (up conversion to 720p or 1080i is a REAL plus!!!)
* Have enough optical inputs for said sources as well as the usual compliment of analogue sources.
Those are the MUST haves. Anything else might be nice but is optional. As for price I'm a little constrained. I don't want to spend any more than $2000 Canadian, about $1700US and hopefully less. Name brands are nice but mean nothing to me all I want is quality at a good price. If I can get the same quality by going with a no name brand I will. But I won't sacrifice quality to get more features. All I need is in the list above.
One reciever that I am looking closely at is the Pioneer VSX-81TXV. Not sure where I could find it in Canada though, or a good place on the net that would ship it here. Also it's a little pricey.
Many thanks in advance for ANY help I can get!
XBox 360
PS3 60GB
old VCR
