World Wide Stereo
Am I over cabled? (1 Viewer)
Hello to all.
I subscribe to the Dish Network and receive satellite programming through a single DVR 510 receiver. My main viewing in on a Pioneer Elite 510HD television located in my entertainment room. I also have non-HDTV television sets in three other rooms.
The installer who cabled my two Dish Network 500 satellite dishes and receiver connected them and a Terk roof terrestrial antenna in a way that allows me to view satellite and local stations in four separate rooms.
TI do not believe the image quality displayed on all four of my television sets is as good as it should be. I think that the reason for this less than optimum quality might be signal degrading bcause of too many connection devices.
My first question is, do I have too much cabling? Secondly, if not too much cabling, are my devices correctly cabled?
These are the connections the installer made:
Two dish 500’s are cabled to a SW21 3-sat switch. A cable from the switch along with a Terk terrestrial antenna cable connects to diplexer #1 in my garage attic.
A cable connects from the diplexer to a TSDA2150 signal combiner.
One cable from the TSDM2150 connects to a Monster brand splitter. A second cable connects to the DVR 510 satellite receiver.
One cable from the DVR 510 satellite receiver connects to the Pioneer 510 HDTV.
The DVR 510 satellite receiver connects one audio cable and one video cable to a USM-8 modulator. The modulator connects one cable to the Monster splitter.
The Monster splitter has one cable connecting to a DSU-2 splitter.
The DSU-2 splitter has one cable connecting to two different TA15 amplifiers.
A cable from amplifier #1 connects to a VC R. A cable from amplifier #2 connects to diplexer #2 in the garage attic.
Diplexer #2 in the garage attic connects to non-HDTV television sets in three rooms.
In addition to the setup that the installed made, I ran a cable from a second Terk terrestrial antenna that I put on the roof directly to a Pioneer HDTV tuner SH-D09 integrated in my Pioneer 510HDTV. This caabling allows me to receive over-the-air high definition programming directly from local TV stations. It does not pass through any other devices. The image from this setup is superb!
As an added note, I have a Denon AVR-4800 controlling digital and analog feeds relating to the satellite receiver, Pioneer HDTV, DVD, VCR and other devices. No audio problems are discernible from the way I have made connections to and from the AVR-4800.
I appreciate any suggestions.
Thank you.
Maurice
728x90
Grant B
At least you got an installer that knew his stuff since it's more complicated than most.
The easiest option is to get another Dish box and leave one on the HDTV ands the other for the 3.
Before that you might check the coaxes for loose or bad connection which could degrade the picture.
I installed for a while (little $ for a lot of work)an learned not to break the cable more than 3 times on long runs (~100ft or more)
I have my DVR (Directv) going to 4 TVs without a problem using a Channel plus ditribution system.
Is the 2nd one pointed for local channels?
I always hated the way Dish did that.....looks bad and adds a wire nest but you can't get around it.
Hope that helped some
Grant
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Wow, that does seem like a convoluted mess, Maruice. :frowning:
It’s hard to help since you don’t give any indication of signal direction. Therefore it’s impossible to figure this out from what you’ve given us.
For instance:
A VCR connected to a diplexer?? For what, so someone can watch a tape on all three of the TV’s? That’s nuts. As cheap as VCRs are it would be better to just get one for each TV.
What should have been done is spilt the signal from each dish and send an independent run to each TV. Assuming you have good service from the Terk, I would have split it 4 ways and combined the signal with each sat feed with the diplexers, to the three extra TVs. For the main system, I would have sent separate direct feeds from the dish and Terk and used a VCR as a tuner for the local stations (I really don’t like the idea of diplexing the two signals for my main system). If the local stations ended up weak I would have added a second Terk and done a two-way split from both. Or a 3-way split with one and the other direct to the main system.
By the way, no reason to pay a premium for a Monster splitter. Any splitter rated for satellite bandwidth will do.
Wayne A. Pflughaupt
Thank you Grant for your input. I appreciate your comments
I have checked all cables to insure they are hand-tight fitted.
The distance from my dish and terrestrial antennas to the combiner, splitters, amplifiers and finally to the satellite receiver is just at 100ft. This impedes your warning about “not to break the cable more than 3 times on long runs”
The first Dish 500 gives me satellites 110 and 119. These are my local and majority of Dish programming. The second Dish 500 is satellite 148. This is for additional programming.
My DVR 510 is not a HD receiver. This is of no consequence to me because, as previously mentioned, I do get HD directly from a second Terk antenna to my Pioneer 510 HDTV.
Regards, Maurice
Hello Wayne. I am sorry that my post was unclear. I am a home consumer and not well-versed in electronics.
Regarding signal direction, I was told that there are two diplexers in my garage attic. I have not seen them and have GUESSED the paths to and from them. My guess might be in complete error. What I though the installer said that one signal goes from diplexer #1 through other devices to the satellite receiver. Then a signal go back after being converted by the receiver through devices to diplexer #2 and then distributed to TV sets in three other rooms.
I have seen all of the other cables and devices. Based upon what I see connected, this is the path I believe the signal travels:
From two dish 500’s a single cable from each to the SW21 3-Sat switch.
From the SW21 3-sat switch a single cable to garage attic diplexer #1
From the Terk terrestrial antenna #1 a cable to garage attic diplexer #1
From diplexer #1 a cable to TSDM2150 signal combiner.
From TSDM2150 two cables. One cable to a Monster splitter and the other cable to the DVR510 satellite receiver.
From TSDM2150 one cable to the Pioneer 510HD television.
From the DVR510 receiver one RCA audio coaxial cable and one RCA video coaxial cable to a USM-8 Modulator.
From the USM-8 one cable to the same Monster splitter that also received a cable from the previously indicated TSDM2150 signal combiner.
From the Monster cable to a DSU-2 splitter.
From the dSU-2, two cables. One cable to TA-15 amplifier #1 and one cable to TA-15 amplifier #2.
From TA-15 #1 a cable to a VCR.
From TA-15 #2 a cable to garage attic diplexer #2
Diplexer #2 sends the signal down cables to three different TV sets.
The one VCR is used to record off of the one satellite receiver.
Except for the RCA audio and video cables, all other cables are RG-6’s.
The reason for two amplifiers, I was told by the installer, was because of the 100ft distance between the dishes and the receiver. The signal had to be enhanced going to the VCR from amplifier #1. Amplifier #2 sends the signal back to diplexer #2/.
The VCR does not connect to a diplexer. Cables from the VCR connect to the Denon AVR-4800 receiver and the Pioneer Elite TV.
Wayne, I do thank you for your comments. If I were more knowledgeable, I might be able to convey a more intelligent response.
Regards, Maurice
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
How is ”down cables to three different TV’s” accomplished? You can’t connect all those cables to a single diplexer. There must be additional splits somewhere.
As I noted, Maurice, all these splitters combiners, etc. have their connections labeled. It will be impossible to sort this out unless you can tell us what those labels are for each and every item. E.g., “One of the Monster splitter outputs goes to the ‘antenna in’ connection on the DVR510 satellite receiver. RCA cables from the DVR510’s video and audio output go to an input of a USM-8 Modulator.” And so forth. Or maybe you could post a flow chart.
Wayne A. Pflughaupt
Hello Wayne
I am learning as I read your post and recognize just how little I know. Once it cools down here (today the temperature will be about 105F, I will go into the attic and actually look at the diplexers and whatever splitters are there.
I will also check the ID ports on each of the connectors near the receiver.
Once this is done, I will TRY to do a flow chart.
Don't hold your breath because our temperatures here are going to stay quite high until October.
Nevertheless, I appreciate your comments and will try to digest and learn from them.
Regards, Maurice
Grant B
The more I read your post, the more I am amazed everything works!
When you say 'image quality' is not as good as it could be...what exactly is the problem as you see it?
Quality differnces between the Dish & Ant?
Can you bring up the meter on the menu and find the singnal strength on all 3 sats? HD is Sat B and most others are on A
Rough estimate in feet from Dish to Sat Box?
Sat box to TVs?
Grant
Hello Grant
Instead of my making this situation clearer, I seem to be making it more muddled each time I respond. Perhaps, I should wait until I can go into the attic to actually see the cabling, splitters and diplexers there.
I live in Arizona and this time of year, attic temperatures reach 160F. At seventy-five years of age, I cannot handle that kind of heat and must, therefore, wait until October to climb up a ladder and go into the garage attic.
The cables and connection devices I described in detailed in my earlier posts are located directly next to the satellite receiver and my Pioneer HDTV. I have never actually seen the mess in the attic.
But, to answer your questions:
I have had the installer to my home twice. The first time was a number of years ago to make the original installation with a Dish 5000 satellite receiver. From that time until recently when I replaced the 5000 with a dVR 510, I had crisp images on my Pioneer HDTV and on the TV’s in three other rooms.
Two weeks ago, I replaced the 5000 receiver with a the DVR 510 satellite receiver. At that time, the installer made changes on the cabling and on the SW21 3-sat switch alongside of the two #500 dishes. Since then, the images of all of my TV sets has been less crisp. The image at times even appears to be a bit out of focus.
The distance to my satellite receiver from my two dish 500’s and my terrestrial antennas is 100ft (by way of passing through the garage attic).
I get strong signals from each satellite (110, 119 on one dish and 148 on the other dish). The signals range between 85 and 102.
By passing the dish and the satellite reciever, I get outstanding HDTV images on the Pioneer. This is by way of a cable directly from the terrestrial antenna to the Pioneer HDTV Tuner on back of the Pioneer HDTV set.
I do not receive HDTV via the Dish Network because I do not subscribe to HDTV programming and nor is the DVR 510 satellite receiver an HDTV receiver.
As I mentioned to Wayne, I am a novice in this matter. Looking at the switches, combiners, et al is confusing to me. I have related what I see in the way of cables going into and out of the connection devices.
Rather than take more of the time from you very helpful people, I believe that I should try to learn and understand more about what I have and where it goes before I ask more questions.
I do thank all of you for your suggestions and comments.
Maurice
Grant B
It's hard to say since I can't see the images but I have a DVR and a HDTV reciever and I have both going to each TV.
My DVR picture is not as good as my HDTV picture (on non-HD channels)
When they 1st came out I bought a external DVR since I already had a reciever.
It dawned on me what was going on
Digital from Sat to Dish and reciever....
converts it to analog sends to DVR.....
DVR converts to digital and stores.....
converts back to analog for viewing......horrible picture!
Combing the two helps but you still get some loss from storage
Marv74BR
