Ahmose
Grip
- Dec 14, 2002
Hello and thanks in advance for any advice.
We moved into an older house which unfortunatly has ungrounded outlets. The house itself is grounded, however the outlets are not (there is no ground wire, only live and neutral).
Ofcourse, i don't want to do any major renovations $$, if i can avoid it. The people at the hardware store recommended that i install GFCI receptacles instead.
My question concerns if i can use power conditioners like the Exact Power 15A and surge protectors like the Brickwall with an ungrounded outlet ?
I suspect that i cannot use the brickwall, since i've heard that surges get routed to the ground wire. Can it work with the GFCI ? Does the ExactPower 15A work with an ungrounded outlet ?
Or am i out of luck and have to cough up the money getting the ground wire installed ?
thanks again or your time.
