Brad Dixon
- Jan 10, 2002
Well if work slows down this week I'll be ordering an amp and sub. I've got the sonotube and mdf already. I realise this is a somewhat personal/loaded question but, any opinions would be helpfull.
Room size is 15x13x8 with a 7' opening(on 13' wall) going into dining area. Also has a 3' opening to hallway on 15' wall leading to rest of house. The sub would be placed in a corner as that is only place to put it.
Purpose of sub will be HT primarily very little music other than an occasional family get together. Given that even though EBS for single is 340L, a ~533L tube(gross) with dual tempest should vibrate and break things.
Given the room size though I'm just wondering before I order the components if it will be a marked and noticable difference compared to the single? I'm sure the single must come close to breaking things as I don't recall seeing a post stating it was anything but awsome.
Since I want to feel the movie I'm pretty sure the dual is the way to go but I wanted to ask since the room is pretty small.
Amps I'm looking at are amp350 or ava250 for plate amps or qsc850(if dual route). Haven't made up my mind on that yet.
Brad
Brad
