Larry Chanin
- Jul 24, 2001
I've got a home theater in which I have a home theater computer (HTPC) with a pretty decent audio card, permanently connected to my A/V receiver. After reading a number of threads on this forum discussing the use of acoustic software to do room frequency graphs, it occurred to me that my HTPC might lend itself perfectly to such an application.
BUT… I'm not a Do-It-Yourselfer, or an audiophile, so I don't want to go overboard (like I usually do), by buying a lot of expensive hardware and software just to calibrate my equipment once in a while.
For my first foray into this area what I'd like to do is see if I can use some of this software to more scientifically integrate a newly purchased subwoofer (which the manufacturer claims will to go down to 18 Hz) with my old, Polk SDA main speakers.
With the help of this forum I've located a number of freeware and shareware programs that provide Audio Spectrum Analysis software that I plan to experiment with, and I've got the following equipment:
- A 1 GHz Pentium III PC with an M-Audio Audiophile 2496 Audio Card with RCA analog inputs.
- A Radio Shack Sound Pressure Level Meter (and I located the thread on meter correction values).
- I also have an old Ekectret microphone (with a low end frequency response of 30 Hz) that came with a Graphic Equalizer. It has a long run of cable terminating in a 1/4" plug.
- Which microphone should I use, the Radio Shack SPL meter's or the Ekectret?
- If I use the Ekectret do I need some sort of calibration data similar to the Radio Shack correction values?
- Do I need a microphone preamp between either the Radio Shack or Ekectret and the audio card? My audio card's manual says, "In order to preserve its high dynamic range and minimize distortion, the Audiophile 2496 does not have microphone preamplifiers built into it. Therefore direct connection to a microphone is not recommended. Instead pass the microphone signal through a microphone pre-amp (such as the M Audio DMP2™) and then connect the pre-amp output to the input of the Audiophile 2496."
- If so, can you recommend a suitable, inexpensive microphone preamp?
- I've seen a few web sites that have free downloadable test tones, as well as commercially available test CD and DVD's that range in price from $7.95 to $150. For low frequency response analysis what type(s) of test tones would you recommend?[/list=a]
Thanks in advance for your help.
Larry
