Paul_Scott
- Jul 19, 2002
Just pulled out my copy of the sd SE of A Room With A View, and feel I can state definitievly this is from a PAL master. The pitch issue is definitely there- and I can also detect a fairly slight, semi-regular slurring of motion/resolution that is a tell tale sign of PAL- NTSC conversion. The visual issue isn't nearly as apparent as the audio issue, though.
I only hope that in advance of the work on this HD DVD (which I'm greatly loking forward to) that if the resources are not there to strike a new non PAL: converted transfer, that at least the audio can be digitally corrected to the correct pitch.
Actually, now that I think of it, Warner probably has little to do with this since they are merely distributing it. Does anyone know how responsive the BBC is to quality control suggestions?
