Jeff Sch.
- Nov 30, 2001
Ok well i finnally got My Kenwood vr-507 reciever, N26's, Ncenter and Sawm40 sub up into my dorm room. After pulling all the speakers out and setting them where they will go, I pulled out my Monster home theater kit and took all the wires out. It seems that the speaker wires have gold pins attached to the wire. What should i do with these. My reciever and speakers have banana plug inputs and the pins are to small. Right now i slid the pins through wire holes and tighted up the screw down onto the pin. Is this bad? Should i cut off the pins and strip the wire clean and use just the wire?
Next, the monster wire didnt have any arrows on them, just red and black at each end. Does it matter which black end goes to the reciever and which goes to the speaker. The same for the sub, which has an arrow. Does the arrow on the sub cable go to the sub or away?
Ill will post more questions as they come up, because you guys are the best and you got me this far, so i figure why stop asking questions. Thanx
