Brad Dixon
- Jan 10, 2002
I've talked to Kyle a little on this but figured it wouldn't hurt to ask here aswell. I'm not exactly sure what's happening but I've had 4 fuses blow on the Keiga amp.
Now what's weird is that it doesn't do it while watching movies but it appears to happen during the day or night when we aren't using it. I'll go to put in a movie and notice there's no low end. Sure enough the fuse is popped.
I'm going to try a good surge protector in the next few days. Right now I simply have a cheap one that I added *after* talking to Kyle. He had asked if I was running one.
I don't think this would be the Keiga or Tumult otherwise I believe it would do it on a more consistent basis. That leaves the house wiring or the wall plug. I've had the setup running for a few months so it's not like this happens constantly but enough to be bothersome.
For those that may have seen something similar what did you do to fix/stop it? Would it take an extreme such as running a dedicated line for the amp(and other HT equipment) or even upgrading the circuitbreaker box? I live in an older house and only have 75-100 amp service I believe. When the AC or the fridge compressor turn on it causes a quick dim of the lights. I've talked to a couple electricians and they said that's not uncommon in an older house.
I'm just trying to give some background.
Brad
Brad
