Brad Craig
- Feb 1, 2002
1 >>> I was looking into some Klipsch surrounds w/ the 180 degrees Wide Dispersion Technology (WDT) and the picture showed the speakers adjacent to the sides of the couch versus being slightly behind... Does anyone know if Klipsch recommends these bipolar spks be adjacent to listner on both sides or should they be slightly behind as well like you do w/ most typical monopole speakers???
2 >>> I was looking into getting a Home Theater Universal TOUCH SCREEN Remote and had my eye set upon the SonyAVR2100 or the new 3000 model but you cannot find them in my local area, So can anyone recommend a TOUCH SCREEN HT remote that doesn't get way over complicated (w/ internet and to many functions that nobody would ever use) and falls in the $200 or below range??? Or am I dreaming of finding something like this???
Just give me any recommendations that come close to the $200 mark of slighly above if nothing comes to mind in the $200 and below mark ~ The problem by the way w/ the Sony 3000 model is they haven't released it yet, don't know when they will...
Oh yeah I would like a few programmable macro buttons if possible...
3 >>> Okay confuscious speaks, I hear of this and this show being shown in high definition, so do I need a hdtv tuner built into my TV to get the show in high definiton through my normal cable or satellite receiver lets say???
What would happen if i watch it on a high definiton ready TV w/out the built in card??? How would it look or sound???
Also I hear of "off the air" and "on the air" being used to describe broadcasts >>> what does this mean exactly???
