Darren_H
- Jul 22, 2001
I've had this TV for half a week and I just thought I'd let you know what its like.
I have mixed feelings about this television. I'll go over the good stuff first.
GOOD:
The Price: For $300 you get a 27" TV with component and s-video inputs, 2 rear A/V inputs, 1 A/V output and 1 front A/V input.
Video Quality: Really good except for a few things that I'll mention later. I hooked Monster 3 Component cables to my DVD player and it really has made a big difference. Watching DVDs through composite cables is now almost an eyesore. S-Video is also pretty nice.
Now on to the bad. Alot of nitpicking here but there are a couple things that I really hate.
BAD:
The Speakers: I really don't like these speakers. They're only 2.5 watts and sometimes it sounds like you're listening to things through a tunnel. Even the speakers on my 3 1/2 year old 19" Sanyo sound much better.
Picture Issues: Like the earlier "A" series, this TV also has a problem holding Black level. The picture is tilted about an inch clockwise. It can get annoying whenever text is on screen. BTW, can someone let me know if problems like the tilted screen would be on every 27A41 or is it just my set. I need to know if I have to return it or not.
Ok, back to the picture issues. There is blue line not even a centimeter wide on the upper right edge of the picture and things get sort of greenish as you go down. Then on the left side of the screen I see the same thing but the line is orange-yellow. These aren't always visible though. There is a patch of the screen that is darker than the rest about 4x4" in the upper left corner of the screen. Only really visible on whites. Finally there is a minor geometry problem in the upper right corner.
Other: I wish this TV had multiple memory settings for picture and the remote sucks!
Like I said earlier, can someone tell me if I should return my TV for another based on the picture problems above or should I not bother wasting my time?
Darren_H
GOOD:
BAD:
Darren_H
