Steve_Ma
- May 7, 2001
How does one calibrate the sub in relation to the mains when connected via the speaker level inputs? Can this be done with internal test tones?
I do not own VE/Avia, but borrowed a copy awhile back to confirm my test tones were accurate. They were fine. I had my sub connected via the LFE out. I now plan on experimenting with repositioning the sub and different x-overs by using the speaker level connections between the AV Rec (fixed x-over at 100Hz), the sub (B&W ASW1000) an the mains (B&W 603S2).
--Steve
--Steve
