Kay_A
- Sep 4, 2001
Hi all, a newbie question from a real newbie.I just bought a receiver and speaker set and can't wait to hear that with proper setup but dont know what to buy. I just use the cables i have for now.
What type of cable should i use for connection from subwoofer out in receiver to my subwoofer (LFE)? is it a ordinary RCA cable or a special cable. My sub is 8", 35hz-120Hz (is it quite good?).
Another question, what will happen if i connect dvd to receiver via coaxial terminal with ordinary RCA cable?
Last question, I heard that i must use the correct size for speakers wire. If the wire too thin, It will lose some frequency (cut the hi/lo from the range), if too thick, there will be some noises. Is that true? So how to choose the correct size (and also type ) for speakers wire.
What cables should i buy for those connection (please specify the type and size, if any)
Sorry for those too stupid question. Many thanks for any response.
Kay
Kay
