ShaneH
- Mar 5, 2001
Shorting straps for my towers are MIA , and will be using old receiver that has spring clips which I'm pretty sure will not accept 2 twists of 12 gauge. Other option , run 12 gauge to bottom posts and run small length of 12 gauge up to top posts. I assume this will be the same as shorting straps? Any negatives to this method? Any other options? I dont want to pull out the 18 gauge wire again. thx
