Benny G
- Sep 5, 2001
Can someone please explain the relationship (if there even is one!) between ohms and the # of speakers powered by an amp?? Thanks in advance.
If you absolutely must have several speakers feeding off one amplifier channel, it's best to mix the two wiring methods to achieve a finished impedance matching the ideal levels for the amplifier. So for example, you could have a two sets of 8 ohm speakers wired in series giving you a 16 ohm load, and wire those sets together in parallel to get you back to 8 ohms.It probably should be added that there is “no free lunch,” as it were. While a series/parallel combination like Vince described will result in the amp seeing a favorable impedance, that doesn’t necessarily mean “all is well.”
For instance, if it took only 15 watts to drive one of the speakers to your normal listening level, the amp will theoretically be pumping out 60 watts to drive all four speakers at the same level.
So any way you cut it, your amp is always working harder driving multiple speakers. That’s why it’s best (for the sake of reliability) to keep a single speaker per amp channel, as Vince recommended.
Wayne A. Pflughaupt
