Daniel Simon
Grip
- May 11, 2000
Ok, I have settled on my mains now - PSB Image 2B (this will be for a more 'budget-orientated' HT setup). I plan to add a pair of PSB Image 1B speakers for my rears, and the Image 8C for the center. That would then leave the subwoofer. I was previously thinking about getting a 10" one. But now I'm wondering if that is the right choice, or would it overpower my compact setup? The room size it will be used in is about 14' x 16'. Should I consider just getting an 8" subwoofer instead or stick with a 10"?
Second question: my entertainment center is rather large and crosses a corner of the room diagonally, instead of sitting adjacent to a wall. This leaves a fair amount of space between it and the corner (large triangle). Would it be ok to sit the subwoofer behind it, or would it dampen the sound too much?
