Jim_C
- Feb 6, 2001
Administrators:
I don't know if this belongs here but I figured that it was my best shot. If it should be moved then please do so.
My speakers:
Main: Klipsch Kg-4
Center: Klipsch Kv-3
Surrounds: Klipsch Rs-3
I was re-calibrating my system with Avia last week and when I ran the tones I noticed that the left speaker was 1 dB lower on the sound meter. I switched the L+R speakers and re-tested. Now the right speaker was lower by 1 dB.
I've verified that it's not the amp (switched in a pair of Kg-3's) and that the problem is following the speaker. I set the main volume to output a reading of 85 dB on the sound meter. I get 85 dB from all the speakers but this one. From the suspect speaker I'm getting a solid 84 dB. It doesn't matter if it's connected to the L or R channel it's still reading lower. I verified that my bass management as well as all of my connections are set up properly
The thing that worries me is that the last time I calibrated I didn't measure/hear a difference. Sure, the two speakers weren't EXACTLY the same measurement but they were close. Now there's a clear difference. I don't know if something's wrong but I suspect that there is
I don't know an awful lot about the guts of a speaker so I don't know how to diagnose the offending part. If it's a driver will it continue it's downward spiral and become obvious? Any other ideas on what it might be? If there's a problem I'd like to try to fix it before any more damage occurs.
Originally I thought that the main speaker that was reading higher was the problem. I've come to the realization that it's probably not that one.
Any ideas? Please help.
You want to upgrade again?!!
[Edited last by Jim_C on August 31, 2001 at 08:59 AM]
[Edited last by Jim_C on August 31, 2001 at 09:01 AM]
My speakers:
Main: Klipsch Kg-4
