BrianW
- Jan 30, 1999
- Brian
John, all I know is that I get at least 20 hours of play time between charges, and the battery indicator (which is undoubtedly non-linear and deceptive at low capacities) still shows 50%. I use the display a lot -- something not allowed in the 35-hr claim -- so that's fine with me. I have no intention of finding out how long it will run on a single charge. (See #2 for an explanation.)
I know the comments you speak of, and I encourage you to consider the following:
1. Play time is heavily determined by the headphones you use. In fact, the longer the battery life, the more your choice in headphones will affect the actual play time.
2. Lithium-ion batteries are a fantastic leap beyond NiCd and NiMH, but they can be abused. The best way to abuse a Li-ion battery is to repeatedly deep-cycle it. (Conversely, repeated deep cycling is actually GOOD for NiCd batteries.) Occassionally depleting a Li-ion battery won't hurt it, but doing it repeatedly will. Some of the posters on that forum have conducted battery tests by repeatedly deep-cycling ther batteries, and they've found that with each rebound, the batteries had diminished capacity. Well, DUH! Don't do that!
3. Does anything measure up to its marketing hype when it comes to battery capacity? "Up to XX hrs" claims always assume, if not unrealistically ideal circumstances, at least tightly-constrained conditions. The Samsung player has been documented to be able to play for well over 45 continuous hours without headphones attached. At least they didn't claim that worthless stastistic.
Yeah, the 35 hours is definitely marketing hype. But if the number of hours it will play (which current owners are willing to divulge before you buy) doesn't intertere with the way you intend to use it, and there's plenty of margin to spare, isn't that good enough? I was aware when I bought it that I probably wouldn't get 35 hours, especially since I also use mine to store and view family photos. But I'm very happy with the play time I'm getting.
Also, if you plan to use the Samsung as a data stick, you'll have to carry the USB cable along with the player. That's not very convenient. If your a "briefcase" kind of guy, however, this may not be an issue.
Johnny, do you require an FM tuner or voice recording capability for your TX-FM replacement?
