The Outlaw ICBM works in analog mode. It takes analog output from a multi-channel DVD-A or SACD (or receiver or preamp) and does bass management for the setup as per your wishes.
John Kotches
Contributing Writer Link Removed
Takosan: Yes, they are both analog external crossovers.
But there is one important difference. The X-30 is 2 channel and the ICBM can handle up to 6 channels (plus the .1 LFE channel.)
As John notes, THE reason for the ICBM's existence is the fact that the multi-channel formats SACD and DVD-A have minimal or no bass management during playback.
I own both an Outlaw ICBM and a Paradigm X-30. In fact, I replaced my X-30 with my new ICBM. I wanted to have ALL of my bass management controlled by the ICBM. (I have bypassed the bass management in my processor.) By choosing to do so, I can add an SACD or DVD-A at any time and have full bass redirection. A big added plus is that the ICBM allows different crossover settings for the mains, center and surrounds. For now, mine are 60 Hz(mains), 100 Hz (center), and 120 Hz (surrounds). So far, I am very pleased with the ICBM in my setup.
If you have any specific questions, I'd be happy to help.
Just a thought. Can i use this with my receiver? My receiver has default xover set at 100mhz. Can i take my 6 pre/outs then into the ICBM and then back into my 6 channel input of the Marantz and now have full control over my bass management with the ICBM?? Thanx
Brian: No, because in order for you to hear the ICBM, you would have to choose the 5.1 input as the source. So the CD, DVD, Tuner and whatever would no longer be playing...
Download & take a look at the manual. http://pdf.outlawaudio.com/outlaw/docs/icbm_manual.pdf It will show the different hookups that the ICBM can accomplish.
------------------ [Edited last by Chuck Kent on October 14, 2001 at 12:20 AM]
Thanx all! Along the lines of what Brian was saying I guess we can feed Outlaw's ICBM an amplified signal?
Brian: I guess you & I were thinking about the same thing. I too have the Marantz & was thinking along the lines on bass mgmt using the pre-outs. In the past I've read about using the pre-out & then feeding it back through the Marantz but never tried it.
Takosan
Takosan: FWIW, I would be more comfortable in saying that the ICBM can accept PRE-amplified signals (ie. sitting between a pre-amp and an amp.)
