Cagri
- Dec 18, 2002
Well I've just bought an optical cable to hook my CD player along its good ol' analog connection so that I'll compare the sound. My receiver is in a closet and I had a hard time to fit the cable to the receiver trying to locate the place of the input jack by the help of a mirror and a torchlight while the doggy was picking me at the back, man it was a tough work! Anyways, the receiver is a Denon 1802 and I guess the toslink input doesn't have a protective cap cause I couldn't feel anything to be removed and I forced the cable into the receiver missing the hole several times and I possibly scratched the tip if it gets scratched by the plactic frame on the receiver's input. I countless times touched the tip as well by the way.
My question is; how sensitive are these optical cables? If I don't hear anthing wrong with the sound shall I assume the cable is OK to use or are there any risks using a damaged cable?
Thanks for any input.
