Shannon Berry
- Dec 31, 2000
Well what we did/tryed to do was, make a digital out cable that can just plug onto the SBLive sound card on my friends computer. He brought it around today and we hooked it up to the coaxil input on the reciver.
We got no sound at all so we didnt bother with it to much, but after that there was no sound with anything, TV, radio, DVD's, nothing, not even a static hum you would expect...
We thought it might have just blow a fuse becasue the voltage of the signal may have been to high, but we couldnt see any blown ones.
Everything works like it should, all the options displays etc but just not sound at all....
Anyone have anyideas what might have happened or if there is something i could do to fix it ?
Should I just take it to an electronics store and get them to fix it...
The Reciver is the Pioneer VSX-D608
Thanks guys..
PS. I checked all wires, made sure it wasnt muted or anything little like that.
Thanks guys..
