Mark Guidry
- Dec 28, 2001
I am about to order some speaker wire from bestbuy.com because I have $100 gift card from them. I need to know what kind of speaker wire to get. I was planning on the monster XP or the "Original" which one would be better...is there a big difference between them? I think the XP is 12 gauge not sure about the "original" might be 10g. I am also going to put the monster banana plugs on each end. One of the runs needs to be like 12-15' the other can be as short as 5'...should I keep the lengths the same or will that make a difference???
Mark
Mark
