Sheldon C
- Dec 27, 2001
I'm curious why most pics I've seen of HT setups on this sight have the main speakers so close together. I have heard that the mains need to be at least 3 feet from the side wall, so that could explain some of it. However, if you have the space for it, shouldn't the mains be the same distance from each other as they are from the listening position (forming an equal sided triangle basically)?
Is there a difference is optimum distance between mains for music and movies?
