LCD Projector Colors Out of Alignment (1 Viewer)
Andrew Parnell
Back in june I purchased a Panasonic LCD projector off of eBay.
For about the first 2 months I had no complaints what so ever. However recently the convergence drastically went out of whack. Currently the red is shadowed about 1/10th of the screen to the left, and the green about 1/20th to the right.
Does anyone know if this is something I can fix myself and how? Or is it something that'll need to be replaced/professionally taken care of?
-Andrew
ChrisWiggles
Well, sounds like it needs to be fixed. That's a pretty crazy misconvergence though, usually it's only off by a few pixels or less. So it is somewhat possible that it's something else, but if you are certain it's just panel misalignment, aside from repair...
if it's not worth much, or you paid little for it, you could try to do it yourself, but success is probably unlikely.
phyllisbernhard
