Steve Stogel
- Jul 19, 2000
When EQing, I know you really don't want to boost the valleys, that you want to lower the peaks (saving valuable amp power). Well, in EQing, I wanted to boost a couple of frequencies. If I drop the Main down 3dB, am I okay boosting up frequencies that much? It would wash out, wouldn't it?
Here is what I did:
20Hz...+3
25Hz...+2
31.5Hz...+3
40Hz...-11.5
50Hz...-6.5
63Hz...+1
80Hz...-3.5
MAIN...-3
So should I be okay as far as not losing any amp power? BTW, from 15-80Hz I'm between 84.0 and 89.5, so +/- 2.75dB. From what I've read, I think that should do. Here's the pre-EQ/post-EQ numbers:
HZ PRE POST
15........88.0dB...........87.0dB
17.5......88.0dB...........87.0dB
20........84.5.............84.5
22........85.5.............85.5
25........86.0.............84.0
28........84.0.............84.0
32........85.0.............85.0
35........94.0.............86.0
40........99.5.............85.5
45........96.0.............85.0
50........94.5.............86.5
56........90.5.............84.5
63........87.5.............87.5
71........92.5.............89.5
80........91.5.............88.5
I'm so anal, I think I'm going to try to EQ that little hump out of 63, 71, and 80. If I can get them below 87 and above 84.0, I'd be +/- 1.5dB . I think it may be a waste of time, but I thought it was fun playing with the EQ (my wife did not have the same enthusiasm, however ).
So am I okay boosting 3dB if my Main is down 3dB? They cancel out. Correct?
Steve
Here is what I did:
20Hz...+3
25Hz...+2
31.5Hz...+3
40Hz...-11.5
50Hz...-6.5
63Hz...+1
80Hz...-3.5
MAIN...-3
HZ PRE POST
Steve
