Tim L
- Jun 30, 1997
I am in the process of insulating my romm which was previously a garage- my question is one of the walls had to be framed with 2x3 studs because of an adjoing door entrance into the house- can I use the same insualtion I used ont he 2x4 walls (R-13 faced)but just trim a little off the thickness off the insualtion pieces to make it fit better in the 2x3 bays instead of trying to stuff the whole thing in- which I believe will be counterproductive in theinsualtion properties because of the lack of air-pocket betweent he cement wall and the fiberglass insualtion- any advice appreciated. I thought this would be easier than cutting foam insualtion pioeces and them putting up my own poly vapor barrier- thanks in advance
Tim
Tim
