Bill_Wheeler
- Nov 19, 2002
OK got the 811S coming this week from Goodguys.com and I was looking for opinions on connections. I have a Panny Tau 32" HDTV with the following
4 Svideo/Composite video connections (1 in front)
2 Component video connections
6 stereo audio input connections
1 variable stereo audio out (labeled out to amp)
1 composite video out
One of the main reasons, other than the incredible picture, I got this Panny Tau was because of all the wealth of connections for future expandability. I current have the following hooked up to the Panny Tau.
Component 1 - Panasonic RP56 DVD
Component 2 - GameCube
Svideo/Comp 1 - Dish 4900 Upgraded (optical out not connected)
SVideo/Comp 2 - None
Svideo/Comp 3 - Proscan Hi-Fi VCR (old)
SVideo/Comp 4 - None (this is the front panel connection)
How does the 811S fit in? Should I just hookup the Panny Tau's Variable Audio Out to the 811S? This would make switching from one connection to the next easier rather than having to switch the TV setting and the 811S setting each time. Would this arrangement lose the Dolby/DTS signal coming from the Satellite and DVD since I would be going through the TV's variable audio out? Another minus would be I would not be utilizing the optical out on the Dish 4900 or the Panny RP56 DVD in this configuration.
The more complicated connection scheme would be to hook each components audio out(analog or digital/optical) to the 811S reciever and the video to the TV but would entail multiple switching with different remotes to get the audio and video in sync, I think. I'm so confused......HELP!!
Edit: FYI the Speakers are the following
7.1
Mains - DCM Time Frame TF400 (Floor Standing)
Surround - JBL N24s
Rear - JBL N24s
Center - JBL N-Center
Sub - Sony SA-WM40
The DCM's have been sitting in the garage for 2 years so who knows if they work at all, so it might be N24S for Mains and Surround in a 5.1 configuration. N28s maybe later to go 7.1
7.1
Surround - JBL N24s
Rear - JBL N24s
Sub - Sony SA-WM40
