Wade
- Jun 30, 1997
My wife and I are looking at putting both a water softener and a reverse osmosis system in our new home. I am having the builder put in the soft water loop and reverse osmosis line from under the sink to the refrigerator so we're ready to go for both systems. I have been reading a lot on-line about how both of these systems waste a lot of water. We've never had these systems before so I didn't know how they worked or how much water they wasted.
Can anyone recommend a water softener that regenerates based on demand and not by a set schedule? It looks like the Kenmore models do this but I'm not sure about the GE models. Any other manufacturers we should be looking at (Culligan maybe, but probably expensive). From what I understand, soft water will not be supplied to the kitchen sink or outside hose bibs. This should help to cut down on the number of regenerations. We're only a family of three right now but I'm thinking we should probably buy a little bigger unit to account for any future growth.
Is it true that reverse osmosis will waste up to ten gallons of water (depends on unit) for every one gallon of purified water? If this is the case then I may just go with a dual stage under the sink filtration system and be done with it. How do these systems compare to the reverse osmosis systems?
Is a whole house filter overkill if you're only going to be drinking water from the kitchen?
Wade
Wade
