asi_a
- Sep 21, 2004
I'm sure some if not most of you will know how to fix my problem. I have a Denon 2805 running Axiom speakers(80 fornts, 150 center and 3's for side and rear surround. Everything works and sounds good but I feel like the system is lacking volume for some reason. Is there a way to bring up the volume level? as I said the sound is very clean and I am happy with the setup with regards to clean and clear sound but it definately needs more volume.
Thanks in advance for any help/advice.
