Ricardo E Garcia
- Aug 28, 1999
I'm in the planning stages right now and I've found a spreadsheet that Stereophile Guide to Home Theater had on their web site that is supposed to help you in selecting room dimensions that are sonically correct. Here's the location of the sheet
http://www.guidetohometheater.com/shownews.cgi?388
I punched in the numbers of my proposed room.
27L x 14W x 9H
and the sheet showed several flaws in this room size. 12 problem frequencies to be exact. And 6 of them are below 180Hz.
I played with the numbers some and found the best I can do is 4 problem requencies and the lowest one is at 221Hz.
But now I have a room size of 24L x 12.73W x 7.55H I'm losing quite a bit of space.
Does anyone have any suggestions on maybe some other proposed dimensions that would allow me to keep more of my room and still be sonically correct?
Thanks!
Rick
27L x 14W x 9H
Thanks!
Rick
