James Elvick
- Jan 12, 1999
Great small room or bedroom setup! Used in a den for less than a month, I just don't use it!! Perfect condition with all original packaging. $300 plus $25 shipping in the upper 48! PayPal preferred.
Rocket Loudspeakers is proud to announce the brand new 5.1 Rocket Tyke system. Featuring all extruded aluminum enclosures, the Tyke system will offer (4) 2-driver, 2-way satellites, a 3-driver, 2-way center channel, and a 100 W (RMS) powered, ported subwoofer. Included are wall mounts for the satellites and center channel. PERFECT for bedrooms, offices, game-rooms, etc., the Rocket Tykes offer the detail, resolution, and performance even WE had a hard time believing! And that's not even the good news...the complete system is yours for just $499.
Satellites:
High quality, all aluminum construction with NC machined components. ▪ 2.5” long throw woofer with 1” voice coil and Neodymium motor structure with unique, precision made progressive suspension system for low distortion and high output ▪ 3/4” silk dome tweeter with Ferro fluid damping and Neodymium motor structure ▪ Internally damped cabinet Full L/C crossover with tweeter overload protection ▪ Precision large gauge speaker terminals ▪ Universal Threaded insert for wall mounting ▪ 5 3/4" high x 3 1/8" wide x 4" deep(including binding posts and grill) ▪ Smooth, flat frequency response from 80Hz-20KHz +/-3 dB
Center Channel:
High quality, all aluminum construction with NC machined components. ▪ Dual 2.5” long throw woofers with 1” voice coils and Neodymium motor structure with unique, precision designed progressive suspension systems for low distortion and high output ▪ 3/4” silk dome Neodymium motor tweeter with Ferro fluid damping ▪ Internally damped cabinet ▪ Full L/C crossover with tweeter overload protection, optimized for center channel use. ▪ Precision large gauge speaker terminals ▪ Universal Threaded insert for wall mounting ▪ 3 1/2" high x 9 3/4" wide x 4 1/4" deep(including binding posts and grill) ▪ Smooth, flat frequency response from 80Hz-20KHz +/-3 dB
Powered Subwoofer:
Compact down firing, front ported design for extended low end and high efficiency ▪ High quality MDF cabinet with internal damping ▪ Long throw 8” subwoofer with rubber surround and heavy duty motor assembly ▪ 100 watt internal amplifier with balanced dual drive topology ▪ Auto turn on circuitry ▪ Variable low pass frequency adjustment ▪ Variable gain control ▪ Fully protected against overload conditions ▪ Adjustable spiked feet ▪ 13 3/4" high x 12" wide(incl. feet) x 13" deep(incl. amplifier heat sink fins) ▪ Powerful low frequency response to 30Hz
Satellites:
Center Channel:
Powered Subwoofer:
