Rob Kulp
- Sep 5, 2001
We recently moved into a new construction house in Florida and plan on living there for 15 to 20 years. I'm ready to start making my lifelong dream a reality by making it a dedicated home theater with a front projection system, flush wall system with built in speakers, and maybe a small stage for the kids.
The room is on the second story and of frame construction. The left, front, and rear walls have R-11 insulation, the right side wall has R-30 insulation as it is a knee wall to the attic.
My room dimensions are:
12'6" wide
20'6" depth
8' height
The entrance into the theater is going to be 125" from the front wall on the right side and my current plan (not set in stone) is to have an 18" to 24" deep flush wall system with the screen recessed in that 6" to 12". My equipment rack will be in the rear right corner (if you are looking at the front of the theater.
The front row seating position has not been determined, hopefully someone has some suggestions for those room dimensions.
My question here pertains to selecting a front projector and screen size for my setup. Features I'd like to have are the ability to watch 16:9 and 4:3 aspect ratio movies and tv. HDTV is a must for use with Time Warner Digital in the Orlando, FL area.
Price of the projector is definately a consideration as well.
Thank you for any input.
Rob Kulp
12'6" wide
20'6" depth
8' height
Rob Kulp
