Chuck C
- Jan 6, 2001
When the "Cinematographic process" lists a movie as "Sperical" What does that mean?
some examples:
Link Removed
thanks for the help
some examples:
Link Removed
thanks for the help
I am POSITIVE that i've seen either oval or round light flares when watching a movie shot in 'Super 35', i'm sure of it.Lens flares can occur with any form of photography, depending on many variables. If you're seeing round ones, the film was almost certainly not shot with anamorphic lenses.
M.
but I am POSITIVE that i've seen either oval or round light flares when watching a movie shot in 'Super 35', i'm sure of it.Spherical lenses give round lens flares, while anamorphic lenses tend to give flares that stretch horizontally across the frame (and the color isn't necessarily blue). While it is certainly possible to use anamorphic lenses when filming for 2.4:1 acquisition using Super35, I don't know of any films in which it has been done. So while you've certainly seen round lenses flares before in Super35 films, if you saw a distorted lense flare, it was shot with anamorphic lenses and wasn't Super35.
DJ
as you can see, others have seen them as well.Others have seen lens flares. Hendrik's point (and mine and Damin's) is that the mere presence of lens flares doesn't tell you what type of photographic process was used.
M.
While we're on the topic, what exactly does it mean when something is said to be shot "flat"? Not in terms of 3-D, but it's often used in conjunction with spherical....are they synonymous?Yes. Flat/Spherical are generally synonymous, just like Scope/Anamorphic.
DJ
so which is "better"? anamorph. or sph. ?They're just tools with different characteristics. Neither one is "better".
M.
so which is "better"? anamorph. or sph. ?Just to build on what Michael said, this is kind of like asking if a pen is better than a pencil. I don't mean that to sound as if I'm demeaning you for asking the question in the first place, but rather I mean that there really isn't an answer. Pens excel in some areas (e.g., permanence, absorption into a given surface), while pencils excel in others (e.g., erasibility, the ability to smudge for shading). So it would be kind of absurd to say that a pen was somehow definitively better than a pencil. Instead, they're just things tools can be used to achieve certain artistic goals, and neither is perfect for every single imaginable job. Same with lenses.
DJ
A better way to spot spherical vs anamorphic is to look at the cigarette burns. You burn a circle on the frame (unless you aren't so good with the cigarette) and if you then show that frame anamorphically that true circle on the cell will be streched wide into an oval. If it is shown flat then the geometry of the circle remains unchanged.
Not exactly. You'll only be able to use this trick to establish whether or not the PRINT you are viewing is presented in 'scope (a.k.a. "anamorphic") or flat. The cue marks (what some call "cigarette burns" - I never heard of that term until FIGHT CLUB) are ALWAYS circles on 35mm prints - they are punched into the printing negative at the lab. The projection lens will make them stay as circles (flat) or distort them to ovals ('scope).
A better way to spot spherical vs anamorphic is to look at the cigarette burns.Seth, if you're referring to the reel change markers, then no, that isn't a good way to spot the difference. Films shot in Super35 (i.e., with spherical lenses) for exhibition at 2.40:1 go through an anamorphic squeeze when release prints are generated. Those prints are then projected through the same lenses used to display films shot anamorphically. So they too have oval-shaped cigarette burns.
M.
Films shot in Super35 (i.e., with spherical lenses) for exhibition at 2.40:1 go through an anamorphic squeeze when release prints are generated.That would make sense Peter and Michael. Thanks for clarifying. I wasn't really thinking about S35 2.35 (2.4) films.
What I really had in mind was that on the film being projected you had a circle and after the projection lens distorts it, you don't. But then since spherical capture with intent to mask to the wider aspect still requires the 2.40 to fit on the projection print somehow...
