Geoff L
- Dec 9, 2000
- Geoff
Anyone that can offer suggestions!!!
Help on finding a repair center authorized or not, (IN GRAND RAPIDS MICHIGAN) that dose good work at reasonable prices. Unit is no longer under warrenty!
I need a Yammi EQ-5000 worked on. Probly an easy fix as everything works properly except the RTA window shows light bars stuck wide open.
Meaning all frequency bar LED's on the RTA go to the top when turned on, -{even when EQ is in BY-pass mode}- ~~~ Aside from this, everything works perfectly! Subsonic filter, tape loops, line pass threw, all the eq sliders lights, along with adding or subtracting gain on all freq slides work perfectly. also there is no noise added to the sound it produces in pass threw or active EQ-ing....
Im no electronic wiz, but something tells me this should be a easy fix!!!
So any suggestions or recomendations for repair shops in the Grand Rapids area that are not going to steal you blind and do quailty work? There is always a fee to crack the cabnit open but some places really put a scewing on you. It's been years sence I've had to have some thing worked on and the place I used to go to is not around any more, (mom and pop shop and he passed away) and thats to bad because they were excellent at home audio repair and very reasonable.
Thanxs
Geoff
Thanxs
Geoff
