Ted Lee
- May 8, 2001
hey all -
i'm thinking about using a hole-saw to drill some holes into the back of my office furniture, so i can pass wires through, etc.
problem is i'm concerned about cracking/splintering/whatever the laminate. this is the cheapo build-it-yourself-type office furniture you get at ikea, etc
i'm thinking a couple of things:
1. get a fine-tooth saw. that should cut cleaner?
2. put some tape over the area i'm going to cut
3. drilling halfway through, then finishing the drill from the other side. something about minimizing splintering?
does this sound right to you guys? any other suggestions?
thx!
thx!
