Mark_Sykes
- Aug 9, 2002
Setting up first home theater system and could use some input before finalizing. Mostly will be used for watching movies with minimum audio listening. I appreciate the replies and help that I have gotten in the past. I have read and searched this board a lot lately, but I’m still learning. Have the receiver narrowed down to either H/K AVR125 ($275 etronics) or AVR325 ($499 Costco). Setup will be 5.1 with slim possibility of going to 7.1. Will upgrade TV to HDTV in future so the AVR125 doesn’t have HD outputs and the AVR325 does. How important is this?
DVD player will be Panasonic CP72 ($218 crazyeddie)
For the speakers was thinking about the JBL S38II bookshelfs ($265 etronics) and I need a center channel that would compliment the JBL’s, but the dilemma is it has to be 18 ½ inches or less in length. The JBL Scenter ($130 etronics) is 20 ½ and wont fit the cabinet. And for the sub JBL PB10 ($185 etronics). I only need these 4 speakers as there are already two ceiling speakers for the rears installed. Total cost is around $600, would there be something else to consider over these in that price range, give or take a little.
I'm going to a couple of home theater stores this week to listen first hand, so if you could give me some brands to check out - great.
That would put me roughly at
AVR325 $500
CP72 $220
Bookshelfs $265
Center Channel $130
Sub $185
Total $1300 (less $225 if I go with AVR125)
Also another $200 for cables, speaker wire and a copy of Avia.
If I want to run everything to the receiver what cables will I need for these items (TV, Digital cable box, Receiver, DVD, VCR, Speakers, Sub, PS2)
Trying to stay around a $1500 budget and don’t plan on upgrading for quite a while. So something that will last, if there is such a thing
Mark
AVR325 $500
CP72 $220
Bookshelfs $265
Center Channel $130
Sub $185
Mark
