Eric_RP
- Oct 31, 2002
HELP!
I am experiencing a buzzing noise through my speakers. My setup is: Denon 3803 - Main pre-out (L & R) is split and input into 4 separate channels of my Classe CAV-180 to passively bi-amp my main speakers. Center pre-out is input to 5th channel of Classe amp. My surround (L & R) and rear surround (L & R) pre-outs are input to B&K AV5000ii amp with the 5th input capped with shorting-plug. With the system hooked up this way I get a buzzing sound out of my mains (mid and tweeter not the bi-amped separated woofer) and my center speaker. If I turn off the B&K amp (the amp is positioned directly on top of Classe on next cabinet shelf) the buzzing is greatly reduced to acceptable level.
I have disconnected everything and I don’t think it is a ground loop. I have a dedicated HT 20A circuit and I tried cheater plugs on both amps with no change.
I thought it may be something with splitting the main signal and inputting it to the same amp, so I tried switching inputs so the woofer output of my mains went to the B&K amp and the surround speaker pre-out went to the Classe with the rear surround remaining hooked to the B&K. Weird thing happened, the buzzing sound came from the rear surround speakers then??
I would like to figure out what is happening so I can enjoy for a while prior to possibly going to a dedicated pre-pro, B&K Ref 50 (I will need to save some cash to upgrade). If I upgrade to the Ref 50, with my current amp and speaker setup, I would use the RCA outputs for the woofer output and the XLR outputs for the midrange and tweeter I would not be splitting the signal and I’m thinking that that is the basis of my problem.
Please reply with any suggestions.
Eric
Eric
